I had an acquaintance that worked for Ace hardware that sold Rheem. He advised he had gone to a Rheem seminar and the instructor there told them the only difference in the warranty period was the price tag. ( Like a lottery )My understanding is, there is no difference tank wise from a 6-9-12 yr tank.
Usually the 6 yr tank will have one anode rod, while a 9 or 12 will have two anode rods.
Anode rods keep the tank from rusting but wear out.
I usually use reem, never had any problems
@chandler48 In-the-street natural gas is NOT available. I have a leased 120gal propane tank (fire a lightly used fireplace insert) but propane is more expensive here than electricity.Do you have gas available?
It may depend on quantity. You will probably have 3 each 40 amp breakers dedicated to the electric water heater alone. Granted the 120 gallon tank may not be enough. We have a 320 gallon, but run gas logs, gas stove in basement, whole house generator and the Rinnai. We fill once a year.propane is more expensive here than electricity.
@Missouri Bound I like this unit. I have moderate hard water. The price at Home Depot is about $1200 for the 40gal. I like the much longer warranty for the tank and less likelihood of leaking.I bought a Marathon.....it is basically a plastic thermos.
It has a lifetime warranty against leaks.
Rheem's Marathon Water Heater is the Most Durable Water Heater Ever Made - Rheem Manufacturing Company - Rheem Manufacturing Company
Its award-winning construction makes the Rheem® Marathon® water heater the most durable electric water heater ever made. And its industry-best warranty makes it a smart purchase you can count on for years to come.www.rheem.com
@Matt1963 Yes, please, see if you can find anything about that new WA law that HD is invoking. When I changed my HD "set my store" to a Beaverton, OR zip code, it said I could pick up one of their in-stock units in the store within 3 hours.I live in Washington and install lots of tanks so I will look this up...not sure what that is. If Washington adopted something you know Oregon did too so I doubt that would help.
I use Bradford whites but just about any brand should be fine for 10 to 12 years.
Are you on the west side of the mountains like me or in eastern Washington?
@Chris616 Agreed. I wrote to HD about this, this morning. If reply has anything substantive, I'll post here....older ones in stock...
