1 - 19 of 19 Posts
If it isn't in the tube, consider a piece of all thread cut to length with a clip on each side. Knock the sharp edges and burrs off the ends so you don't hurt self. Or if You be real good a couple of grooves can be cut cut in a smooth bolt with a dremmel cut off wheel and round the ends so it looks purdy.
Discussion Starter · #9 ·
I tried the towing pin clips but they were just too difficult to set in place, not to mention I'd need these extensions to come off easily while outside in subzero temperatures.
My roof rake still had 2/3 functional snap buttons so I took the lower one that never needs to be removed and replaced it with a bolt that I applied locktite to:
Just as an fyi, I thought I lost the same clip, but it turns out it was just pushed up in the pole. Take a flash light and look inside the pole.
Must be different in Canada. I have a relative that is a manager for Fastenal in the states, and they welcome retail sales, but focus on larger commercial accounts
1 - 19 of 19 Posts
