These are 70's single hung, single pane aluminum frame windows.
Sweat & mildew like crazy in the south, especially central gas heat. The deteriorating seals may be replaceable (vinyl & "felt") - not sure it's worth it - maybe.
Windows have nailing flange - over a 1x4, nailed on outside of studs / sheathing. Used to do remodeling - never switched one style window for another. Most were wood.
Inside, 1/2" sheet rock butts close to the aluminum frame - covering the 2x4 opening.
Doubt I can afford the labor to replace them (if done right).
Assume "replacement" windows for this construction, you'd cut the aluminum frame loose from its nailing flange w/ sawzall, or...?
I would NOT want to put much, if any force on bricks, removing old frames. Mortar is soft ( portland).
For the replacements, do they normally tear off the ~ 3" wide strip of sheet rock? Whether to get old windows out, or make replacement installs "go better" - overall?
Or don't touch the sheet rock, get windows a bit smaller than the side to side sheet rock opening, then use snap-in gap filler strips? Or several options?
Same on outside - if vinyl replacements - use snap-in gap filler next to brick veneer?
Not sure how durable / long lived the gap filler strips are in southern sun?
Old windows also have wood stools inside - butt against aluminum frames, & tiny apron. Both easy enough to remove - one piece, or just replace.
