I have a lot of questions about a variety of subjects for this project.
My plan is to replace all the masonite siding on my house, with help from my brothers, with 8" (7" reveal to avoid facenailing) hardiplank lap siding and harditrim. Its a tall task, literally, with the house going up 3 stories in some places (and a total of 1000sq ft of siding to replace). I will be renting scaffolding for majority of the work, but there is 1 area that is puzzling.
How do I work vertically on a pitched roof? (see attached image)
One side of my house looks to be problematic. From peak to peak, it is at least 8ft (probably 10). I'm not very good at measuring the pitch, but its about 8/12 or 9/12. We will be using roof jacks for the front (probably in conjunction with harnesses), but I can't figure out this area.
How cold is too cold?
I live in Houston, where the day time temps are in the 60's typically, with occasional 70's and 50's. If it would help (or at least wouldn't hurt), I plan on preparing (painting) the siding in the garage prior to install.
Sheathing (and radiant barrier)?
Currently, there is no sheathing on the exterior. It is studs, with batts of insulation between, then tar paper, with masonite siding over. Not even the corners have sheathing. Do I need to add some OSB (or plywood?) sheathing to the house? How beneficial is radiant barrier on the siding? yes, I have researched and know I need 1" furring strips between the radiant barrier (be it TechShield or otherwise) and the vapor barrier.
Construction waste/disposal?
What is the most cost effective way for a home owner to dispose of construction materials? My trash service won't pick it up.
