1 - 7 of 7 Posts
Hi Guys,
I've made a short video of the problem as I'm having trouble putting it into words, "A picture is worth a 1,000 words" (Or video in this case)
Thanks in advance,
Jon
Although I've retired from an industry that required installing thousands of compression fittings with service pressures as much as 1,200 lbs. pressure and as little pressure on home plumbing jobs, not a single person other than my former employment superiors and the written instructions on the box has ever acknowledged this fool proof way to do it.
On installs with new ferrules, place the nut on the tubing, place the ferrule on the tubing, insert the tubing into the fitting until it bottoms and stops. Run the nut up with your fingers until it stops. Now while making certain the tubing remains bottomed in the fitting tighten the nut 1 round, that's right, 1 round while holding the fittings mid section with the second wrench ( a backup ). Yes, that's why that fitting has a Hex shape in the center.
Now here is something for some novices. If you are unable to make 1 complete round because of obstacles in the way, 6 hexes = 1 round.:wink2:
If you are inclined to apply some king of mucky puck crap to make it seal better, grab your tin or tube of plumber's grease, 3 in 1 oil or singer sewing machine oil and lube the threads little. Being this is a swaging operation I usually lube the ferrule also.
Note: this is for home plumbing and not for industry fittings such as Swage Lock, Parker and others. They have their own instructions which usually recommend 1 round plus 1 or 2 hexes more.
Or you may like to confer with an engineer.
https://www.beswick.com/speak-with-an-engineer/
Discussion Starter #4
On the isolation valve the leak is on the bottom half, not on the section with the green corrosion & also the connection at the Faucet leaks, depending on the position of the pipes.
The pipes don't join together "Smoothly" and have to be held together where they join at the isolation valve, in order to connect them up.
Discussion Starter #5
I've put in new ferrules, this did not resolve the problem
1 - 7 of 7 Posts
