1 - 15 of 15 Posts
I changed out the exhaust fan, an old 25 year old model for a newer one yesterday. I did a simple swap. The new one has quick connects, but when I flipped the switch it tripped the 20 amp breaker. In the toilet area there is a 2-gang box with 2 switches, one for the light and one for the fan. The light continues to work, but when the fan switch is flipped to on it trips the breaker. The wiring is 12 guage from the switch to the fan. The fan has something different, but I don't think this should be causing a problem.
Don't understand why this is happening. Adding pictures of the new fan (box the fan came in) and quick connects.
Anyone have any ideas? Thanks in advance for your help,.
Joed, thank you! I will look at that. I did tighten the cable clamp a bit tight. I had no idea that would cause a problem. I am adding another picture. This is the clamp you are saying may be too tight? If yes, how tight should these clamps be? Thanks again.
Thank you all for your replies and especially to Joed and HandyAndyInNC. The problem was the clamp was on too tight. I loosened it to a 'snug' fit and all is well - problem resolved. I tried to reply from my iphone yesterday but could not.
Discussion Starter · #9 ·
Thank you for the feedback roughneck. I'll take a look at this and pull the wiring through a few more inches to verify if there was any damage to the wiring under the clamp. Or, would there be damage in other areas in the wiring from the switch to the fan? Since I have the walls cutout already I can easily replace the entire wire from the switch to the fan - about 8 ft long. Would the damage be visible on the wiring jacket along the length of the wiring, (or under the clamp)?
Discussion Starter · #14 ·
I did not reply before, but thank you roughneck and joed for your input/advise. I did find that the overtightening had caused some damage in the cable jacket and the wires. I managed to pull the cable through about 6 inches, cut, and reconnect. The fan is working.
1 - 15 of 15 Posts
