This one has me scratching my head.
I replaced a ballast in a 4 lamb 48" fluorescent fixture this morning. I replaced it with the exact same model as originally in the light fixture and wiring was pretty straightforward.
When I first turned it all back on, only the two outer bulbs were in it, and they both lit. Put the bulbs back in the inner sockets and ... nothing. So I turned it all off again, and turned it all back on, thinking that firing it up with only two bulbs did something to it. Well, then both inner bulbs came on, but not the outer. Now, I had not moved the bulbs around. So I took them all out, checked all the connections, and then the inner bulb in one set of two and the outer bulb on the other worked. So I got up there to see if I should switch the bulbs, and unscrewed one of the ones that was on... and the one of the pair that was off switched on.
What gives?? ballast is a 4 bulb one.
