I am doing some remodeling and I wanted to replace a 25 year old light with a recessed light and add a second (actually wanted to do 3 lights in one string - sorry not an electrician so not sure the name for this, but it is a daisy chain of 3 lights on the existing wire/switch) recessed light. I removed the old light fixture (picture below) and added a new 6" inch led recessed light. All went well - the light turned on. I then added a second light by adding additional wire (Type NM-B 12/2), everything is on 12 guage as I have 20 amp breakers, the length of the new wire is about 8 feet. I used the quick connects that came with the new light fixtures - easy to connect; black to black, white to white, green to ground. The second light is a 4" led recessed light. I turned the light switch on to check the second connection and the breaker was tripped.
The old light has a 60 watt max lamp warning. The 2 new light fixtures, as they are LED use 14 watts (6" light) and 9 watts (4" light) I figured the combined watts, as they do not exceed 60 watts would not be a problem. Adding the 3rd 4" recessed light, an additional 9 watts, for a total of 32 watts would still not be a problem.
But I don't know why adding the second light caused the breaker to trip.
Any ideas?, Your help is greatly appreciated. Photos attached.
