Hello, going to start painting my house 1 section at a time over the next 1-2 years. I have some cracked shingles here and there that I'm going to replace as I've got two boxes of extra cedar shakes.
My thinking is to cut out bad shingles with a blade. Then either tack or nail? Not sure which I should use and what size? Also, Don't I have to treat new shingles before I can paint over them?
I've spent time going over the paint vs stain debate. I had a friend of mine who works for Sherwin Williams look at my house and recommend the lifetime paint over the stains. I do have a latex stain on there now that's at least several years old but dried out. However, no flaking or anything so it was done right. My friend also said to take my time and go slow and work on dry days to be sure no moisture is trapped behind the shingles before I paint. This is how to avoid paint pealing. However, some shingles are starting to curl and crack because they are so brittle.
HELP.
Thank You,
~Skelleyman
HELP.
Thank You,
~Skelleyman
