Water heater is only 2 yrs old, but I think its my bad water line? should I replace?
dielectric unions. get some.I think its my bad water line? should I replace?
Replace the plain galvanized nipples with dielectric nipples.
Its hella tight, won't tighten anymore.The new one looks just like the one you have on it now. It's probably a good idea to have it 'in hand' before you start working on it. I would start by attempting to tighten the connection. If that stops the leak, you're done. If not, take it apart at the leaking connection and check the end of the pipe nipple to make sure it's flat and smooth. If it's rough, you'll need to either smooth it up or replace it (or try one of these).
