This is an a garage that was converter to livable space and there are four outlets on one wall that tare either broken (plastic on box) or don't fit because of the layers of drywall. I could try to repair them but since I'm running conduit around to other parts of the room I was hoping to just remove the outlets and put a box like (https://www.lowes.com/pd/RACO-2-Gan...rd-Square-Ceiling-Wall-Electrical-Box/1098475) over it and then just use that for the outlet. Is there any issue with doing that?
The NM wire would come from the back of the box and transition to thhn to run in the conduit. IN the photo below another layer of 1/2 drywall is going on which would put the box behind it plus the screws are broken on the existing box
