Hi,
I am have a 3-gang box with one 3-way switch. I have replaced the 2 single pole switches with wifi smart switches and want to replace the double throw switch with a single pole wifi smart switch. It is suggested that I can do this by leaving the secondary switch on and wiring up the smart switch. However, I have been unable to do this correctly, in part b/c I am confused by all of the wires in the 3-gang. Based on the photo, I have created a diagram, both of which are attached.
The smart switch has Neutral/Live/Load & ground connections. It seems that I want to connect the Live, Neutral, and ground from the A/c panel to the smart switch and keep the common as the Load? Unfortunately, this did not work for me. What do I do with the wires that I believe are coming from the secondary switch? Any suggestions on how to easily make it work?
Thanks in advance for any ideas .
~Mike
~Mike
