1 - 6 of 6 Posts
So, I got my hands on this 48" lawn roller where it was left full of water over the winter which expanded, splitting the seam open as per the attached pics. I plan to try to bend this back into shape after heating it with a torch and then weld the seam shut.
Has anyone had to do a similar repair... I believe I will also need to wrap a chain or heavy duty strap around the roller at the widest spot and tighten it gradually to pull the seam closed.
Please share any ideas / thoughts on best way to repair this.
648909
648908
Super Moderator
Since I don't have a heat source, I would beat as much as I could then chain or ratchet strap it closed as much as I could. As the seam closed I would start stiching it together at the end working towards the middle with more beating and chaining.
A heavy-duty ratchet strap will probably work to pull it together. I would not use chain, due to the pressure points that may cause local buckling.
Thx for the tips.. I also had another one about welding on two "weld dogs" on either side of the seam and using a C-Clamp to pull the seem together. I will post a follow-up with what actually worked best after I get some time to work on this!
Your on the right track. The "weld dogs", chain or strap will work.
Just tack it first then come back.
If you wind up with a strap, keep it soaked.
And measure.....measure.....measure.
Would you consider a metal band that you could put around the drum and tap it along as you weld?
You will still need a strap but the band would keep the diameter consistent.
And of course you may have to cut it off when finished.
1 - 6 of 6 Posts
