Hi All,
I’m a newbie to the forum, but look forward to reading all the wonderful advice and tips.
I have a little problem that I’d like to get some feedback on if possible.
What began as a simple tile repair job, has turned into a full on shower replacement due to some rot I discovered underneath the shower. Apparently the custom built shower pan (from previous owners) wasn’t built correctly and the curb failed, causing a leak. I’m replacing with a pre-fab multi-piece shower.
The problem is that the rot is on about 3-4 studs and the bottom plate of on an exterior wall (see photos). The rot only extends about 12-18” up the studs and about 6 ft of the bottom plate. The subfloor is also rotted and 1 of the floor joists (2x12) has some discoloration and just a little bit of softness toward the top 1” in the one corner, otherwise it’s solid.
I’d rather not have to tear off siding to replace the plate and rotten wall studs if I don’t have to, and I’d rather not have to replace the floor joist either for such a small amount of damage to it.
Any ideas/tips/etc on how to approach this from the inside? I appreciate the help.
Thanks
Thanks
