Hi, I recently discovered a roof leak by way if finding mold on a ground floor wall. Water was leaking down 3 stories behind the water barrier and then found a route inside at a bathroom vent. Hopefully the water leak is now gone but a few more rainstorms will verify that.
I have removed the moldy and stained drywall and insulation, and have the room contained and sealed.
I am stepping through my remediation plan but since I now have pictures I thought would share and ask with my grateful thanks in advance if anyone sees anything that deserves special attention.
A few things I am worried about, one is some of the wood studs have some level of water damage, the completely rotted wood I have removed, for the most part the studs seem fine but have a minor amount of rot around a few edges, should they be replace entirely or just cleaned of mold?
Another trick will be the ductwork at the top turns up and goes up one more floor directly in front of the path of the leak, so that will be an obstacle to deal with that is new for me as I am sure I have to remove the ductwork to get at the molded section of the second floor.
Any thoughts would be greatly appreciated. here are a few pics attached, I have more as well.
