I need to repair a 4 inch hole in a plaster ceiling caused by water damage. It was a slow leak ignored by the previous owners. It was caused by a bent nail on the asphalt roof that poked through the top layer of shingle. I fixed the leak. The plaster directly below the nail was brittle so I chipped it out and was left with an irregular 3-4in diameter hole. The plaster ceiling is from the 50's smooth in texture and is on a gypsum backer (no lathe).
How would you patch this?
I also have several 5in diameter clean cut plaster rounds from recessed lights at my disposal.
I was thinking of squaring off the damage and screwing wood/drywall to backside then screwing a square patch into the backer. I was thinking of using the plaster rounds mentioned above for patch material to avoid a height difference. I would proceed to taping the joints with paper/joint compound (sheetrock brand with green lid) and Sanding / applying more compound until smooth. I read somewhere that it may improve joint compound adhesion if I applied a latex primer prior to patching.
This will be my first attempt at plaster repair or drywall repair for that matter.
