I would like to hear from someone who has attempted the to jack up the floor that is sagging around a fireplace.
The building is a two story cottage built in the early 1900's. There is a good concrete foundation and 18" high crawl space over a dirt floor. There is a fireplace in the center of the cottage with a red brick foundation. The main beam runs the length of the cottage and sits on poured concrete pillars that look servicable. The pillars are spaced about every 10 feet. The main beam also runs along side the fireplace foundation. The center of the cottage sags 2 or 3 inches. I believe the fireplace and pillars have settled over the past 80 - 100 years and hence the sag. I think the weight of the fireplace contributed significantly to the sagging. The hearth trimmer on the side oposite the main bean has also split.
The hearth and floor are even and the brick facade is in good shape.
If I attempt to jack up the main beam I will certainly not lift the fireplace and it's foundation. If I raise the floor two inches to remove the sag, the hearth will now be two inches below the floor - right?
The hearth trimers should "slide" up the chimney foundation - right? They would not be tied to the chimney foundation except maybe with a few nails.
It is very likely the fireplace will be inoperable after raising the floor so I should remove the hearth and mantle and facade and cover the hole.
I would appreciate any input from members who have atempted this.
