I have an exterior porch with a Polgal sunroof that I removed and plan to keep off. The rafters under the Polygal are load bearing and have some sun damage and minimal rot in a couple pockets.
When I say sun damage, they just look older than the rafters that were not under the Polygal, but i think they are structurally fine.
Should I sister wood to the areas with rot ( once I remove those areas ), or use an ePoxy in the rot, or any other suggestions.
Thank you.
Thank you.
