1 - 10 of 10 Posts
My 30 year old house has wood around the flue instead of brick. The "wooden chimney" is rotting. The house sits under several oak trees. Can the rotting "wooden chimney" be removed above the roof? I'm not sure the rot is just on the chimney. Rot may have moved down . . . .Should I take apart "chimney" and go from there?
I'm not keen on climbing ladders.:eek:
Job like this should be done with scaffolding, not by working off a ladder.
A 'cherry picker' would be another option. Cherry pickers are easy to run and may be rented from industrial rental outlets.
Registered User
If it was one of the houses I built in the late '70's, the framing may go down to the second floor. I attached the chase, of T1-11 plywood to 18' studs on three sides, to get the required clearance over the roof surface with the metal chimney, to the exterior wall siding. Then jacked the whole thing upright, with the Fireplace cantilever floor stopping it from going too far. Then set the roof, built the rake chase wall on the trussed, sheathed roof. Hopefully, only the siding needs replacing....
Be safe, G
Discussion Starter · #6 ·
I think you knew who built my house
The siding on the chimney definately needs repairs. But being just a homeowner, I don't understand some of your terminology. Can you enlighten me.:huh:
Registered User
Is the damaged wood plywood, made to look like vertical boards? Where is it damaged?
Be safe, G
Discussion Starter · #8 ·
Not so easy
No plywood.
The damage is to the cedar siding on the chimney. It's hard to tell exactly how much is rotten. The bottom two boards are practicly gone. On the side all of the pieces have slid off horizontal. The chimney doesn't get much sun, and as wet as it has been, the damage has excelerated. If you need I'll go up there and get some pics.
Registered User
No, I believe you. Cedar has to have wind or sun to dry. Hopefully there is some builder's paper behind it, not osb or plywood. If in an area where it is unseen, I would replace with some cementious horizontal boards. Check behind it for rotten framing material.
Be safe, G
1 - 10 of 10 Posts
