Edge creep. Edges need to be primed and nothing that is out of the normal woods these days is going to live that long in that location.
If I remember correctly the wood came primed and before it was cut and installed I painted all pieces on 6 sides with a top quality Sherwin Williams exterior paint and the painter sprayed at least one more coat with the same paint. I don't think it was oil base. I can't do anything about the mitered corners and seams but I do have access to the back sides of the fascia and of course the front and bottoms which can be repainted with oil base. What do I do about the existing damage? Do I replace the damaged sections with new wood which i don't think can be done without damage to the spray foam roof. Is there a product that can repair the areas?Primed with oil base primer on 6 sides.
Do you have easy access to the inside?
No, it sounds like the same wood we get pre primed, Are you in to replacing a couple feet on the end?If I remember correctly the wood came primed and before it was cut and installed I painted all pieces on 6 sides with a top quality Sherwin Williams exterior paint and the painter sprayed at least one more coat with the same paint. I don't think it was oil base. I can't do anything about the mitered corners and seams but I do have access to the back sides of the fascia and of course the front and bottoms which can be repainted with oil base. What do I do about the existing damage? Do I replace the damaged sections with new wood which i don't think can be done without damage to the spray foam roof. Is there a product that can repair the areas?
I would have to hire someone to do a proper job. It seems that cutting out a 2 ft section with a horizontal cut at the 1x4 is the way to go.No, it sounds like the same wood we get pre primed, Are you in to replacing a couple feet on the end?
Yes with a piece of plywood behind it to hold it all together.I would have to hire someone to do a proper job. It seems that cutting out a 2 ft section with a horizontal cut at the 1x4 is the way to go.
