Hello,
What you want to do is:
1. Remove any left over adhesive from the wall.
2. Remove any loose sheetrock surface paper.
3. Apply Zinnser's Gardz over the brown spots and torn paper face.
Link:
http://www.zinsser.com/product_detail.asp?ProductID=27
4. Upon curing/drying of the Gardz: Apply skim coats of drywall joint compound smoothly.
5. Apply the compound per normal application. Upon drying, sand smooth. (This will take 2 to 3 coats of compound to get damaged areas smooth)
6. Upon completion of smoothing out the wall area: Apply your Orange peel texture per standard application procedure.
Link:
http://www.homaxproducts.com/products/texture/02/index.html
7. Prime and Paint.
This should all be definitely under $100.00 in cost.
Good Luck on the Project.
