I have a very old (20 years?) Aeron chair. The arm rests are wobbly and they do not fit under my desk. So I thought I'd remove them. I did a little research and came across this video:
https://tinyurl.com/ycaztqo6
Following his instructions, I was able to remove the back of the chair. The four hex bolts were super tight. They required a lot or pressure to loosen them, but once I did, they came right out.
The bolts inside that hold the arm rests on are torx. I found the right size wrench, but am unable to loosen them. In the video, he says they are torx and seems able to loosen them fairly easily.
Mine do turn slightly, but whichever way I turn them, they seem to get tighter.
Back to the Internet, I found this method:
https://tinyurl.com/ya3lw5sq
If this guy is correct, H-M locked these nuts in place with some kind of glue. A-holes.
Should I try to apply as much pressure as I can and hope for the best?
Should I try heating the bolt as suggested? And why use a series of ever larger drill bits? Why not start with a larger one?
What about drilling out the head of the bolt?
I don't care if I ruin the arm rest as they were broken anyway. I just don't want to damage the rest of the chair.
