I have fixed, replaced screens, etc on several phones, tablets, etc. A friend of mine came to me with a good one. Her daughter managed to snap the headphone plug off down in the headphone jack of an ipad mini.
I searched online and found a method by which you pull the ink tube out of a bic pen, put some superglue in the end, and jam it into the headphone jack, let it fuse to the broken plug, and then pull it out. Unfortunately, this didn't work for me.
When looking down into the jack, there are a small amount of exposed wire out the center of the jack. If I could just find a tiny enough set of needle nose pliers, I could grab it and pull it out. I tried using some super sharp/fine tip tweezers but they don't have the grip strength. Any thoughts?
I have a collection of "dental tools" that you can buy at hardware stores. They usually come in 3,4,5,6 packs of various configurations. Not sure if one could help or not. In any case they are handy to have.
here is an example at harbor freight. Maybe one could snag the side enough to pull it out. :vs_worry:
http://www.harborfreight.com/6-piece-pick-set-93514.html
Maybe try a straw like a little one used to stir drinks, warm it up a little, stretch/work it over another jack the same size so it fits then work it over the stuck jack? If you don't get it today - sleep on it or walk away for a while... Something will come to you.
