Looking for some advice on a DIY solution to heavy sludge buildup in 6 home radiators (recessed in the wall, circa 1950).
The radiators are hot at the top, and luke-warm to cold moving toward the bottom. It's taking a long time to heat the house.
The standard solution seems to be remove the radiator and flush it with a hose. However, considering the age of the radiators and their weight and the fact it's the winter -- I don't want to go that route yet.
- I'm wondering if draining and refilling the system multiple times will break loose some of the sludge?
- Or if there's another DIY approach that can be tried?
Some pictures of my new boiler and piping. There's a drain valve on the right side. And, a new Fernox magnet trap (installed in October) that doesn't seem to be picking up any sludge -- so either it's not working, or the sludge is not actively moving through the system.
