1 - 20 of 36 Posts
We are going to be removing Sheetrock in our living room and put up new. Above the ceiling is our unfinished attic. We have insulation betwwen the rafters above this ceiling and are hoping it stays put when the ceiling is removed. What is the best way to remove a Sheetrock ceiling? Start going crazy with a hammer ? :whistling2:. Thanks a lot
I just replaced my entire ceiling also. Best way is to go in attic n move insulation out of way n vacuum this one person can push old rock down n get nice big peices down at a time. If u pull down from bottom u will get small peices n make huge mess with insulation. N sheet rock will be more of a pain to take down. Try putting up 5/8 rock instead of 1/2 in. U can rent drywall jack for 30 at Home Depot for day
A drywall lift is the way to go, good point.
Once I bought one I'll never go back to the bad old days of tying to balance it on my head standing on a step ladder and yelling at each other all day.
It can make it a one man job.
I see someone suggesting how to remove it because that's what you asked about, but there not suggesting not to go over.
I've done it both ways. The only time I remove the old is in really old houses with undersized sagging joist.
That way I can sister them to make the whole ceiling flat and level again.
Discussion Starter · #8 ·
Thanks Joe. How to you find the joists to nail the new sheetrock to?
Stud finder, go up in the attic and just drill a small hole on each side of the rafter, look for divits or nail pops in the ceiling.
If you go in the attic and check to see if the joist are evenly spaced, once you find one it's just a matter of marking off the rest.
I like to use blue tape on the wall to mark out where the joist are.
Just going to have to use longer screws when installing it.
· Retired Moderator
Another vote for installing over existing sheet rock. If you have never taken any down, you have missed all the mess, and especially a face full of junk in your face. Try this in an old house where they burned coal.:eek::whistling2:
Your also going to have to deal with the fact the ceiling was installed first and the walls second. So you would have to dig out all the old rock that's stuck in there when the ceiling comes down.
Reactions: Mstrlucky74
The worst ceiling I ever took down was in an old movie theater.
Were 50 ft. above the floor, old stamped steel ceiling panels, then 4" of old news paper laying flat, 6" of celluose, 2" of old pigen poop.
· Retired Moderator
Ewwwww :eek:I thought the coal dust, rat and mouse droppings was bad enough.
Mask, suits, duct tape on ankles and wrist.
We were doing this in a building with no heat in the middle of winter when it was well below zero.
Discussion Starter · #16 ·
Thanks a lot!!!
Discussion Starter · #17 ·
Might remove sheetrock
The ceiling looks to sag in one or two areas( not most at all). See pics. Not sure of this is just settling issues. I peeled a piece of the sheetrock off and it looks like the beam/rafter?? is a low like it my be bowed. As you can see in another pic there is a very straight line crack in the ceiling.My wife is nervous that putting sheetrock over the extg. might stress the extg. sheetrock more. Any advice? Thanks a lot....
Could be a whole lot of reasons there's a crack.
House shifted.
Not enough nails or screws were used.
Poor tape job.
No tape.
Someone stepped in the wrong place in the attic.
Reactions: tcleve4911
1 - 20 of 36 Posts
