If you could make a sluice of 2x4's and the 1/4" screening, tilted up or set on saw horses and wash the dirt back into the soil, it would leave clean pea gravel you could reuse.
Thanks for that input. I think I'm going to make a sifter out of 2x6 and 1/8" hardware cloth, shovel up and sift the actual piles of gravel. But then in places where the gravel is compacted into the soil and not too dense, I'll probably just put the seed and some top soil on it and see how it does.At times Im lazy(smile).
Grass grows in my gravel driveway.
If it was me...
...I'd remove any larger stones, size that would cause damage if flung by the mower.
...Level the area.
...Plant grass seed.
...Add enough top soil to cover the seed. Don't need much.
HTH...Don.
Make it big enough to sit on top of your wheel barrow.make a sifter out of 2x6 and 1/8" hardware cloth
Take some of your soil, place it in a clear jar, fill the jar almost full of water, cap it.Does this soil look like it has too much clay for a dry well to be effective, or would it likely work if when I keep digging there isn't much more clay than this in the mix?
And separate question, does the object in the last photo look like potentially 1970s landscape fabric? I found it while digging, a couple inches below the pea gravel.
I understand. A garden tiller will do a great job, any rental store has them, in demand this time of year.I just used a pitchfork to turn the ground, bringing the dirt to the top and letting the gravel fall down, which I think would help with grass growing.
Do you have a problem with standing water, or excess flooding in storms?So you think rent a tiller to break up the clumps, and then rake it to grade, then the dry well?
