So I recently had a new HVAC system installed (heat pump/gas furnance packaged system). My old system consists of an oil boiler and radiators. I am going to remodel the kitchen and expand into the room where the boiler is located so I need to remove it. The wife also wants the old cast iron radiators removed. So my question is how do I go about this? Here is what I am thinking:
1) Disconnect boiler from electrical, water supply and from oil lines.
2) Drain boiler using drain valve at bottom of boiler (New Yorker, ~ 20 years old)
Now the rest I am unsure of
3) crawl under house (crawl space) and cut piping to radiators one at a time. use buckets to catch water that drains from each radiator.
4) cut pipes so radiators can be pulled up from floor
5) either remove radiator as whole unit (guessing they are very heavy, most are 3' but one is 5-6') or gently break using sledge hammer
6) patch holes in hardwood floors
7) take cast iron to scrap yard to recycle
So any thoughts or advice? HVAC company wanted around $800 to do the job.
Thanks
Thanks
