1 - 13 of 13 Posts
make a poultice of fuller's earth (diatomaceous earth ) & xylene,,, cover the stain w/it then place plastic & cardboard over it so the wind won't dry it out too fast,,, may need to do it several X's,,, works best on fresh stains
Concrete or blacktop driveway?
Discussion Starter · #6 ·
The stains are fairly new. I'll give what you recommend a try.
Thanks
I pour on granular laundry detergent and grind it in thoroughly with my shoe. The detergent will turn into a dark mush.
Then leave it alone until the next rain. The detergent soaks up the oil for several days, and then the rain rinses it away and it is good as new.
Probably not environmentally friendly, but if all else fails dump acid on it from an old car battery. Rinse it well. It might end up whiter than the rest if the driveway, though.
Discussion Starter · #11 ·
I'll try the laundry detergent. I'll grind it in with a brick. My guess is it works because you give it a few days to soak in
Anything recommended stronger than laundry detergent but weaker than battery acid?
1 - 13 of 13 Posts
