When I refilled my hot tub today, it started leaking at one corner. I cannot identify the source of the leak with the wooden enclosure in place. The problem is that I cannot see how to take the enclosure off. I cannot see any fasteners of any kind! I assume that the 4-5 inch boards are fitted together (tongue and groove probably), but until I get one off I am stalled. Any ideas how to start taking this apart without destroying the wood?
While we are on the subject of leaking hot tubs, any ideas what would cause a leak after 4 months empty? The leak is not in the eqpt area where the pumps are, but seems to be in one corner where there is a big set of jets.
Remodel and New Build GC
^^^^^^^^^^^^^^^^^^^^^My bet4 also
I've seen it many times.....
Sometimes continued use will swell or seal it.
You can also get some liquid sealers you pour into your tub that help seal that kind of leak..... sorta like radiator stop leak.... BUT DON"t use radiator stop leak.:wink2:
