I need to remove the outer door panel on a GE dishwasher Model GDT580SSF0SS. Need to replace the control bezel and it looks like I need to drop the control buttons to do so. Can't see any screws holding the panel in place. Found 2 at the bottom edge in the corners but those did not seem to do anything with removing the outer panel so that I can get to the control buttons.
#1 HAWKEYE FAN
it actually simple if you know what to do. You will need to remove the entire door. you may have to slide the dishwasher forward out of the cabinet a few inches. Turn off power, remove bottom toe panel. Find the small door wire connector and unplug it, remove the door cables from the hinge and now you can pull straight up on the door to completely remove it from the dishwasher. Remove a screw from each hinge and remove the hinge. Now you will see 2 screws that holds the door panel to the door. Remove the door panel, remove the control cove by lifting up and off.
Reactions: jmon
