I need to install a bunch of threaded rods in concrete and I'm going to use epoxy (Simpson Set-XP, to be precise). The recommendation is to use a nylon brush and compressed air---at least 80 psi, for a total of at least 8 seconds per hole. I've got the brush, but I don't have an air compressor and would prefer not to buy one. I'm going to have at least 50 holes (5/8" diameter, 4+ inches deep) to deal with.
Is there a reasonable alternative to an air compressor? If not, is there a relatively cheap air compressor that you would recommend? Thanks.
