First time tiling and messed up the bottom row and created a big lip between bottom row and next row up along back wall of bathtub. Decided to remove the bottom row and fix it. After removing the tiles, I was using a scraper along with chisel/hammer to remove the remaining thinset on the wall. The vibration kept knocking tiles loose a couple rows above. These tiles were laid about 72 hours ago, but after they fell off, the backs were mostly clean and the thinset looked damp.
1) I'm fighting a losing battle. The more I scrape the old thinset back to the redgard, the more tiles come loose, and require more scraping. I've tried cold chisel/hammer, just scraping with a stiff putty knife, and carbide grout blade on multitool, but all cause tiles to come loose. At this point, I'm considering removing all tiles, cutting the membrane and peeling it off, then re-redgard the area to start over. Ideas?
2) What am I doing wrong here to prevent it happening second time around? Does it simply take more than 72 hours to bond to the tiles, which is why the hammer vibration is causing tiles to cleanly pop off?
