1 - 20 of 22 Posts
I know this post is old, but I'm in need of some help. I have an elevator I have been asked to remove and I'm not worried about the removal, I'm worried about the stacks of weights on the other end of the chains. One end of the chains are connected to the elevator box, the other has a ton of weights on it. So when I think about it, if I cut the weights off the box's come crashing down, if I cut the chain off the box the weights come down? Ant order in how I should do this? I'm very mechanically cline, I just need like a step process so I don't end up hurt or dead. Haha any help would be great thanks
Discussion Starter · #2 ·
Re: Elevator removal structural fun
Usually the floor is just reframed for an opening--then a support member (usually a lam-beam) is attached for the carriage--then standard framing for the walls--Well in the floor for the bottom of the cage--
Not any special skills needed to remove----Take it away!!
My mother used to wish for a hinged floor in our bedroom --so she could just pull a leaver and every thing in the room would just drop to the basement--
This might be the chance to build a self cleaning kids room-Just a thought.
Can you help with my post?
· Super Moderator
You need to lower one or the other, weights or box. Box is probably easier. Then attach a winch to the cables. Cut cable free from box and lower weights with winch.
· Retired Moderator
I've never worked on an elevator with weights---
How tall is tha shaft? how much heat space above the cage?
· Retired Moderator
I made this into its own thread.
Let's see if anyone else has any experience with this job.
Do you have any pictures of the weights? Can the box be lowered to the bottom of the shaft and then remove the weights a few at a time?
· JUSTA MEMBER
In my understanding of elevator systems, both the car and the counterbalance should both have a locking mechanism to keep either one from falling to the bottom of the shaft in the event of a failure.
So look them over, then lock the weights at the top, and start disassembling the weights one by one and trudging them downstairs.
Then lower the Chain down with a winch to the car, and disassemble it.
just be careful, as these things are dangerous, you have an open shaft, you should have a lot of weight overhead.
ED
how many floors are you talking? height from top to bottom?
I don't think my post was disrespectful.I thought the Op's post was disrespectful to a member of the forum that is very helpful and knowledgeable.It hit a nerve with me and I replied in a decent manner .I thought.
Of course you are the mod and I respect your opinion also.Sorry for any inconvenience to you.
Discussion Starter · #12 ·
The post from Daniel Holzman is the post that was disrespectful, yet you delete mine? What kind of forum do you run here? So I can ask a question or for help and someone can come on here and disrespect me for my question? Seriously? I think the mods here need to look into things before they react. I guess we can just get on a post and make them feel horrible because they ask a question......
Seriously, you plan to take on what by your description is a life threatening project if done incorrectly. And you seek help from an internet chat room? This vaguely reminds me of the post about dynamiting a basement, and looking for assistance in how to place the charges....
:surprise::surprise::surprise::surprise::surprise:
WWHHHHHAAAAATTTTT???
You must find that post and share it! OMG, the things people will attempt!!
· Banned
Reminds me on the episode of Alaska the Last Frontier, when Otto Kilchner kept going for bigger with just about every kind of thing that he could use as an explosive, to take out a stump. Not something you do on your own.
· Banned
How is Daniel's disrespectful when it was the truth. The guy is a licensed engineer and knows what he is talking about.
Unbuilding a Elevator is not something that you just jump in and do. The last thing that happens when an elevator is finished, is raising the counter weights to a specific height, so that they act to help the motor run as spec'd for the max weight of the elevator.
Go talk to a company that works on elevators and they will even tell you to let them handle it and take away the materials. They have the experience in this area and have years of knowledge in knowing how easy the failure or improper dismantling of the mechanical's can kill you if you are not paying attention.
Discussion Starter · #18 ·
Just for the information that the people on here seem to think it's to big of a job for the average person, I did it, it's done, and i did have to pay to have a company or engineer give me input that had no idea on the job I was doing. Thank you to the guys with "helpfull" information. Basically the motor holds the weights in place when the chains are cut, then lowering the weights to the bottom. I didn't need a degree in engineering to figure it out. But is anyone needs any info on one if it's similar I can give you the steps. Also for clarification, I made 2500 and 100 for metal to remove it. Hince the reason I wasn't calling someone else to do it......
The counterweight stack weighs more than the empty elevator car (and less than the elevator car fully loaded).
The car can be moved all the way up (and the weights brought all the way down) and most of the weights removed from the stack.
Depending on the exact weight balancing and car braking, the last few weights might have to be removed from the fully raised position (with the car lowered all the way).
Reactions: gregzoll
1 - 20 of 22 Posts
