1 - 8 of 8 Posts
· DIY'er
I need to remove a large forsythia I would like some tips on what would be the best way to do this Thanks
They are so pretty in the spring. You can cut it back, maybe you could keep it as a smaller bush?
If you want to get rid of it, wait until spring, just after it fully leafs out, then cut it to the ground, repeat as necessary. Then physically remove as many roots as possible.
· KemoSabe
I'd go with the chain and truck idea, only don't use the axle. The tow hitch would be acceptable though. I've removed many a shrub in my yard by pulling them out.
If you soak the soil well before hooking up, many of the roots will come with it. Drop a soaker hose around the base and out to the drip zone of the shrub. Let it run over night and you should be good to go in the morning.
1 - 8 of 8 Posts
