Hi we did finish our existing deck with fiberglass. In order to do that we had to remove the last row (bottom) of the vinyl siding . When they first built the deck they had to cut half an inch of the bottom of that row. So we cannot use a vinyl Starter Strip to lock the bottom of that row in place.
I don't need any flashing cause they "lifted" the fiberglass onto the wall about 4 inches (we'll call it the fiberglass strip). So if the vinyl goes over and down that strip, water will simply fall onto the waterproof fiberglass deck.
I'm wondering, is there any kind of special trim I could use to secure the bottom of that vinyl panel to the fiberglass strip?
Here's 2 ideas that I've thought of already but I'm not sure if they would work :
1-Use silicone sealant to glue the back of the vinyl panel to the fiberglass strip: I've tried it. It works good. It looks good to me. If we do it like that water running down the siding will simply drop on the fiberglass deck. No way for the water to penetrate the walls. Concern: I know that vinyl contracts and expands with temperature. Will the silicone prevent it from expanding/contracting? Or will the silicone simply expand/contract with the vinyl?
2-Use a J-channel : Perforate the bottom of it with a lot of holes. So when the water will fall into the j-channel, it'll have a way to evacuate. There's still a chance that some of that water could freeze there and cause damage during winter.
I prefer idea no 1 cause it's easier to do for me and it looks good.
What do you guys think?
