1 - 8 of 8 Posts
Hey all, I am trying to replace the filter in my GE smartwater GXWH08c and I for the life of me can't seem to get the housing off. I have turned off the water and used the pressure release button to remove the pressure from it. I have bough a strap wrench, and that isn't helping. I've tried to use WD-40 to loosed it up. Anyone else have any ideas / tricks / tips that I can try to remove the thing? Any ideas are definitely welcome, I'm at my wits end with it now.
Thanks,
James
100% sure your turning it in the right direction?
Thanks
Thanks guys,
I was finally able to remove it. Just took a little bit more elbow grease, and a buddy to to stabilize the plumbing around it, so that I could really apply pressure.
Water Treatment
The problems of having a filter with out any kind of bracket for the head to be mounted to the wall with...
Water Treatment
Vasoline?
That could most likely the worst idea yet.
There is some silicon out there that is safe with water use or find another o ring in a plastic bag and most likely there is a little tube of the silicon and it does not take much.
Vasoline will break down and make a real mess of the housing and get into the water.
My water filter did not come with a mounting bracket so I simply installed a 1/2" pine backerboard and secured the top filter housing with a metal strap.
Since we drink and cook with this water, I avoid using any type of synthetic petroleum or water-based lubricants. Instead, I simply use some olive oil to lubricate the gasket.
1 - 8 of 8 Posts
