Let me preface this with saying, I'm handy... but haven't ever done any plumbing aside from simply replacing a leaky pipe/faucet. So please be patient with me.
Also, I'm in Los Angeles California, just in case someone is local and knows any specifics.
I have a 4" cast iron Y where the 4" goes to a toilet and the 2" goes to my kitchen sink and washing machine (my house is old and it's a very slow drain). The Y is slowly leeching waste through parts of the cast iron.
I'm remodelling the kitchen and laundry room. there will be a dishwasher that gets added. there's about a 9 or 10 foot run between the Y and the wall where the appliances will be.
My current plan is:
1. Cut the Y just below where it splits
2. Join new 4 inch ABS Y (where both ports are 4") with one of those rubber couplers (don't know the name)
A. Top 4" will go to the toilet as before
B. Split 2nd 4" into 2 2" lines
3. Run the 2" lines to the wall/appliances with the angle at 1/4" per foot until they go vertical.
Does that seem about right? What changes should I make?
I have a question about venting:
Washer/sink/dishwasher will be on an exterior wall. I was thinking it would just be much easier for me to run an exterior vent then to try and tie into the other ones. How high am I required to run the vent for plumbing? For some reason I have a number of 18" above where it exits the roof stuck in my mind, but can't remember where I saw that.
Also, what diameter pipe should the vent be to accomodate those appliances?
thank you for your advice, I really appreciate it
My current plan is:
