sweaty
I have a Broan bathroom vent fan with a light. I need to remove the plastic cover to caulk the openings between the drywall. Cold air is coming in.
The plastic cover is held up by the metal light assembly. How do I get it off?
Master Electrician
Usually those grills are held up one of two ways. With spring clips…pull the grill down, squeeze the springs together and remove. Or remove the lens, then the bulb, and a screw or nut holds the grille to the metal housing/bracket behind it.
Caulking the grille cover is not a good idea. It needs to be removed periodically for cleaning and maintenance. If there is an attic space where the fan is, I would insulate/caulk up there.
