1 - 18 of 18 Posts
The interior doors in my home (circa 1895) have knobs & mortise locks that are generally easy to remove, but one knob set I can't figure out. There are no visible screws, and the usual advice (remove the trim piece to reveal hidden screws) doesn't apply because there is no trim piece that can be removed prior removing to the knobs.
The knob has a tiny round hole, but when I stick a nail into it, nothing moves.
I tried removing the rectangular trim, but it won't come off because the knob prevents it from moving (catch-22).
As you can see, the mortise lock has no latch, just a hole where the latch is. (My goal is to remove & service the mortise.) The two doorknobs are definitely attached to each other -- they spin together 360 degrees with nothing stopping them -- so I can't pull the mortise out unless I remove the knobs first.
Any advice? Thank you!
Using only moderate force, can you hold one knob and unscrew the other "from the common shaft"?
Reactions: de-nagorg
That hole has to be the means to release the knob. Typically that hole is facing toward the floor but because some of the innards of the lock are missing it can face up.
Try putting the nail in again and probe for the release when the nail is between 4 o’clock and 8 o’clock. Also if there is any in and out play in the knob, probe in both positions.
A beautiful home by the way.
Discussion Starter · #14 ·
Thanks zircon. I tried what you said, but rotating the knob does not change the hole in any way. Whatever is at the bottom of the hole is turning together with the doorknobs.
Also there's no in/out play in the knob.
Actually it turned out pretty simple. I cut a three-quarter inch copper pipe about 3/4 of an inch long and cut one side. I wrapped it around the door knob and put a vise grip on it to keep the base grip for making marks on the brass door knob. Once I had that secure the door knob unscrewed. I did spray a little bit of penetrating oil in the hole to make it go over easier once the handlebars unscrewed the whole thing came apart like it should and you can take the lock out. Hope that helps
1 - 18 of 18 Posts
