1 - 9 of 9 Posts
I need to remove a wall cabinet in the ground floor service porch so that I can affect some repairs on the tile floor located on the second floor and immediately above the cabinets. I don't see how it is fastened; no nail heads or screw heads are visible. This is early 1990's Southren Cali tract home construction. The cabinet is pine. It appears to have a 1/8 " thick back and top.
Any suggestionis on how to get it out with as little damage as poosible? My cheap stud finder is getting some hits, but I wonder if it is just picking up the fasteners in the wall that the cabinet is hung on.
I don't want to even try cutting a hole through the top of the cabinet and trying to bend and twist to access what needs to be done.
I don't know if these pictures will help.
I hadn't thought of a cleat system and since the inside depth of the cabinet is only 1/8" less than the outside measurement to the rear wall, there doesn't seem to be space for any sort of cleat. I can slide a straight edge all along the thin gap betweem the sides of the cabinet and the walls on either side without hitting anything, even a nail. I will pop the molding off at the interface of the bottom of the cabinet and the rear wall and see if there is anything to see or reach with a flat strainght edge.
I imagine I will end up destroying the 1/8" cabinet back, but can live with that. It should be just a piece of plywood.
Failing all else, you can save the doors, maybe the face frame and rip out the rest.
That is a distinct possibility. I don't care a great deal if the 1/8" back is destroyed. The cleats may survive with a bit of putty and if not they are easily replaced. This may give me an excuse for finally buying a pin gun to go with my finish nailer. (Besides I have to build a cedar chest for my daughter's B-Day).
1 - 9 of 9 Posts
