1 - 6 of 6 Posts
I need to remove an 8" SDR35 PVC Gasketed Cap. It's on a sewer access above ground. The brand is Marathon, if that matters. I'm a rookie, although I did search for an answer here and elsewhere. Any kind soul want to point me in the right direction?
Premium Member
That's a gasket fitting. Best way I found is to tap upwards around the perimeter. The older the fitting the harder it will be to remove.
As you're tapping upward, make sure the pipe isn't coming out of the buried fitting too
Sent from my XT1650 using Tapatalk
Reactions: OLD50
1 - 6 of 6 Posts
