Two years ago we purchased our current home, and the first thing was - REMODEL... Beginning with the patio roof. Which consisted of 4x4 treated posts (6 ea) positioned directly onto the concrete slab. 2x6 rafters toe nailed to a 2x10 fascia board, with metal roofing panels ( R-panel ). Nothing fancy but functional.
So with the help of a friend, it all came down. Metal R-panels were repurposed elsewhere, as were the 4x4 treated posts. The 2x6 rafters were salvaged, good condition boards reused, while not so good boards were either repurposed or burned.
New 2x10 fascia boards bought and put up. New R-Panel metal roofing purchased. New 6x6 (actual) cedar boards purchased for posts and headers. New cedar planks (fencing material) was bought for the underside to help conceal the rafters as well as insulate occupants from the heated metal panels in dead of summer.
Here are a couple pictures of the end result...
Single Cedar Post Cedar Ceiling Planks
Wide Shot of Patio
I also drew up some plans for this project with layout, dimensions, material, etc. I have three .pdf's with info written on each. They are as follows:
Sagging Roof-pg1: 2x6x16'5" rafters. 2x4 laths with 2'6" on center. 6x6 (actual) cedar posts and header
Sagging Roof-pg2: Spacing between the 6x6 cedar posts, total of 44.8 feet. On top of post 2, 3, 4, 5, cedar headers have lap joints with a single recessed galvanized screw through the center of joint into center of the post. Beams marked with letter "A", have lap joint on post 2 and 5, continuing over and resting on top of 1 and 6, and extending over the ends by 36".
Sagging Roof-pg3: 2x6x16"5" rafters, resting on the header, secured in place with angle brackets and construction screws. Rafters secured to fascia on the house with hangers and construction screws. Spacing for the rafters is 34" OC, with two exceptions (the center of the roof has two rafters spaced 12 inches apart, and the ends of the roof has 1 rafter directly over top the cedar post, and 2nd rafter spaced 17 inches out onto the overhang.
Finally, the construction has 2x4 laths laid across the rafters spaced at 30 inches OC.
With all this information, my question/s are two-fold.
First, are there any concerns with the construction of the patio remodel? For the most part, I just followed the same measurement spacing, board size, roofing panels, etc as the original. With the exception of the cedar planks for the patio ceiling.
Second, and Much More Important question is: If the is something lacking, which has led to my sag between posts 2, 3, and 4, are there any suggestions forum members would like to pass on to correct my issue? If at all possible, I would like to avoid having to remove any (or as few as possible) of the cedar planks on the patio ceiling.
My first thought was to install a beam parallel and between posts 3 and 4 at about 9 to 10 feet from the wall of the house, supported by 2 additional posts.
Any and All recommendations welcome and greatly appreciated.
Wide Shot of Patio
