Remodeling - best order for projects
1751 Views 9 Replies 10 Participants Last post by  Woodsrdr
Hi everyone. I am separating rom the military soon and just bought a new house back in my home state. I am going to be updating a home I just purchased before I move into it. The house is already in really good condition, it is just outdated (built in 1993). Here is a list of the projects I hope to accomplish in the first two weeks.
Painting walls and ceilings
Painting kitchen cabinets
New luxury vinyl flooring in living room & kitchen (keeping bedroom carpets)
New baseboard if necessary.
New kitchen granite countertops (pro installation)
Kitchen backslash
What is the best order to do these projects in? Im especially thinking about the order when it comes to painting the walls and ceiling, installing flooring, and painting/installing baseboards.
Thank you in advance to anyone that has advice for me.
Austeng88
1 - 10 of 10 Posts
Paint, Flooring, Baseboards.
Countertop and backsplash can be done any time you want within this sequence of events.
I will just add that depending on your flooring installer, it's best to wait till the floors are done before putting on that final coat of paint. Unless the floor guys are real careful, they tend to lean on the walls, sometimes scuffing and scratching them. So I usually paint the ceiling, prime and one coat the walls, then wait for the flooring to be done and fix any damage to the wall, and apply the final coat.
Reactions: 4
i can't see the cabinets. but, imho, painting cabinets is usually kinda cheezy. if you can afford it, get new cabinets. ESPECIALLY if you are getting granite . idk where you are, but i was suprised at how affordable they were, and they look GREAT.
I agree. Get some quotes for new cabinets before you do the granite. I think if you're springing for the granite, it makes sense to do that cabinets too - unless the cabinets are vintage and important to the house.
Hey!! The best order would be:
This will save time as well the construction won't take long also..
I recently shifted to my new house and the room addition contractor followed the same order.
Just to muddy the waters, I'll throw in my two cents. I always remove old baseboards before replacing a floor because I think using quarter round looks cheap. And if you're going to go to the trouble of removing and reinstalling baseboard, you may as well buy new ones (taller ones look better and will cover the outlines of the old ones).
I think Gymshu is right, it's easy to scuff the paint when doing other reno. I'd do the ceiling first then trim out the corners, doorframes etc. with a brush. Then put in the floor. Once the floor is in throw down a dropcloth and roll the walls. Put in the baseboards last to hide the edges of the new floor without quarter round. Since you will put in the baseboards last you won't need to trim at the floor...just make sure you roll low enough to get under the baseboards.
I think painted cabinets can look nice and give life to an old kitchen. If you have hardwood (or wood-like laminate) it can provide some needed contrast instead of brown on brown. Watch some videos on how to properly paint cabinets. Take your time preparing the surface and use a quality paint. If you don't have quality hardware, upgrade to something nice. Replace cheapo hinges with soft close adjustable hinges and make all the doors plumb and level. These subtle adjustments go along way to making cabinets look and feel new. That all being said, if the existing cabinets are of low quality, invest in new ones before installing the granite. If you're painting the kitchen too, trim out the walls while the granite is out...this will save you some taping. Backsplash can't be installed until after the granite goes in. Finish painting after the backsplash to clean things up, then caulk the perimeter of the tile.
Painting and upgrading the cabinets will be easier and more thorough if you do it after the old countertops come out. This would be the very first thing I do, then jump over to the living room for a few days and let that cabinet paint cure before proceeding in the kitchen. After a few hours the paint will be dry, but still soft and easily damaged. Let it harden.
Have fun!
Kitchen backslash
Austeng88
This is a LOT of work for one person who doesn't really do this stuff regularly to get accomplished in 2 weeks.
I do think painted cabinets, with the nice porcelain smooth look can look classy. If a DIY'er could accomplish an average size kitchen alone in 2 weeks and do a quality job, I'd tip my hat to them.
Tackle one thing at a time, take the time to do a quality job and you'll be happy. Flexibility with timeline is the key.
Painting, baseboards and flooring before you move in.
Be sure to paint the insides of all closets while they're empty.
Since you only have two weeks, save the kitchen for after you
move in.
If the cabinets are in excellent condition, then consider
painting them. I would splurge and get a professional painter
for the kitchen cabinets. (this coming from an avid DiY'er)
Although I have painted small pieces of furniture and cabinets,
I would definitely opt for a pro for the cabinets.
Don't rush it, you'll be living with it for a long time, be happy
with your choices.
I'm assuming that after your discharge you will have two weeks without many distractions to complete the work. If this is true, two weeks is ample time to complete the projects.
Remove all base molding from the all areas that will get new flooring. Tape off all other base as well as any crown and door/window trim. Paint the ceiling and walls after making any necessary patches, etc. Paint the the trim next. If reusing base, make any repairs and paint before installation. If using new base, paint ahead of time as well.
Next comes the flooring. Then install either new or original base. Personally, I would replace the cabinets if I were spending the money on granite tops (might make a big difference in resale). In which case I would remove the base cabinets before installing new flooring. In any case, I would do anything and everything to the cabinets before adding new tops. Base cabinets are easier to refinish/paint without a top, so I would at least remove the old tops first. Finally, after everything else is done to the cabinets and tops, add the back splash.
Hope this helps and thanks for serving!
1 - 10 of 10 Posts
