I'm going to replace my current fiberglass tub with a tile shower, and replace the particle board/laminate/Pergo flooring with tile. I need some help with the fine details before I finalize all my purchases and really get going with the demolition. There's pretty much one question per paragraph. I'll underline them for the sake of clarity.
My current sub-floor situation is 1/2" particle board (can be easily shredded with just a screwdriver) over 2"x6"s which are over the joists. The particle board must go, that's for certain. Can I replace it with 1/2" plywood, or would something thicker be needed? Also, is there a specific type of plywood that is better than others? Like birch vs. oak?
I am hoping to use Ditra as a substrate over the plywood. It seems like it would be the easiest for me to install, and it's thin, which is what I need if I don't want to have to modify my door. I'm clear on how to install it, modified thin-set under it and unmodified over it. However, the tile I ordered says to set it with either latex modified thin-set or epoxy. Is this a deal breaker for the Ditra? I've tried calling the manufacturer, but their phone system keeps hanging up on me. The tile is a 6"x6" glazed porcelain tile by American Olean in the Urban Tones collection.
I had a few contractors give me a bid for parts of this project with the understanding that we would be doing most of the work ourselves. Both of them said to put felt paper under the plywood, but that was when we were talking about using HardieBacker. Is this still necessary if I can use Ditra?
For the shower walls I've ordered DensShield, which is pre-waterproofed. Does anyone know if I have to seal around the screws as well as the joints when using this product? The installation brochure doesn't mention sealing around the screws, but it's kind of light on the details.
One more question. I'm installing a Tile Redi shower pan, and the installation instructions call for laying down a thin bed of mortar under the pan. Assuming that everything is properly supported, can I do this over Ditra? I've had a few people say yes, and a few people say no. Which is it?
Thanks in advance for any advice.
