Guys, help would be much appreciated.
Basically my mirrors for my car are wired upto a switch which allows me to fold them in/fold them out. but im hooking up a relay so they fold out when the ignition is on, and fold in when the ignition is off.
Im using an SPDT relay to do this, but have found out that when the 'mirror in' wire is in use, it uses the 'mirror out' as the ground. and alternatively when the 'mirror out' wire is in use, it uses the 'mirror in' as the ground.
Wondering how id be able to hook up a second relay which switchs the ground wire to the opposite wire in use. Or if you have a completely new solution for how i could make the setup work that would be awesome! cheers, Josh.
here is a drawing of the setup before i knew the earths alternated:
