Anyone know if it is very difficult to reinstall a retrofit window? Lowe's installed a window and it is leaking on the inside when it rains. It was a while ago they installed it so it isn't under warranty anymore. It doesn't rain a whole lot in San Diego so we didn't notice it quick enough.
I've actually installed 3 other retrofit windows in my house...none of which leak. Is this simply a matter of pulling the window out, cleaning off everything real good, and just installing it the right way?
Thanks for any advice!
Discussion Starter #3
The windows is leaking from the top part of the sill. I did recaulk it on the outside several months ago when I noticed it leaking due to a gap in the outer caulking. The stucco is a bit concaved at one spot which did make it tricky. The sealer on the inside of the fin must also not be doing anything good.
I did find out a while back that lowe's fired the company that installed my windows and now I know why.
What "W-on-W" says!
Use the right caulk!
"Quad" - "Solar Seal 900" (if you can find it)
Maybe, put a metal "pan" in under the bottom of the window.
Remember - "Drain Plane"!
