We just finished painting a bedroom in our 1920s house, and in the process, removed the entry and closet doors in order to strip old paint from all the hardware, including the brass hinges and skeleton key locks. The doors are different widths, but the hinges appear to be exactly the same -- I measured them. They even have the same Stanley logo on them, which I initially thought meant that the hinges were not original, but upon visiting the Stanley website, I see they have been in business since way before the house was built.
Now that we are finished, the entry door does not close. (The closet door doesn't either, but it didn't before we painted.) It closed without any problems before. We DID NOT paint the edges of the door or the door jamb, so paint is not the problem. It closes to the point where there is about a 1" gap between the door and the jamb. It is hitting the top of the door opening (the lintel?) on the doorknob side -- it probably needs about another 1/16" or so of clearance to close.
There was a spacer behind one of the hinges. I tried the spacer in its original position and with it out, no luck. If I add it to the top hinge, I get more clearance up top, but then the jamb starts hitting the door. The bottom hinge is tightened up as much as it will go.
Incidentally, I did not keep the closet and entry door hinges separate when we stripped them. There are 2 hinges to each door, 2 parts to each hinge, so that's 8 different hinge halves that we mixed up. I didn't think there was going to be an issue since they all appeared identical, but now I'm wishing I had kept them separate for no reason other than I don't know what else could be the problem. The closet door had a dozen pairs of shoes hanging on it for the last 5 years, so I am wondering if those hinges were worn more than those on the entry door. Or maybe the entry door hinges are worn more because it's a larger door.
Any suggestions?
Many thanks,
Dave
Any suggestions?
Many thanks,
Dave
