First post for me on this site, which I found while looking for a solution to my problem so I'm hoping someone might have some good advice.
We bought this house in 2013 and we knew at the time that one entire side of the house and part of the front was going to require regrading at one point because the back fill was piled up over the siding. Last summer I did the front section which is a flower bed, and we found that the dirt was about six inches over, and we could see it was the same around the side. My wife and I had some free time earlier this week, so we started into the side for our spring project. We went down the six inches of over fill and down another four. You can actually see in the picture I've included that whoever built the house put the siding on first, then the back fill, and then added the skinnier wood striations (not sure what else to call them) because the striations follow the original dirt line. I know the recommended distance should be about six to eight inches under the siding, but that's where my problem comes in.
From eyeballing it, it looks like if I go straight away from the house (West) with a slope of 2-3 inches every ten feet, that the eventual ending point would make the soil lower then the curb of the road. I'm not sure what the regulations are about that but I would assume that funneling water into the base of a poured cement curb wouldn't be good over time.
The only solution I could think of is that I should probably follow the natural slope of the street and grade the property so that the water flows South. Technically, that would still be sloping away from the house I suppose?
Any suggestions or insight about this?
