I’m finalizing all of my dimensions for my new walk in shower measurements and have run into a slight problem. I’m planning to end the Schluter shower pan at 33 inches on the measuring tape, and have the shower curb extend out to about 39 inches. I will install the tile threshold along the wall and will end the tile at 39 inches as well. The hinge for the shower door I am planning to install at 34 1/4 inch and will end at 35 inches (.75 inches wide).
As you can see, the register is interfering with the hypothetical tile, but it is trapped between 2 studs on either side. I’m planning to make a notch in the tile around the register, but it will look bad for the tile to be thicker than the register in my opinion. The tile with the mortar behind it will probably be about 3/4 inch. The duct opening measurements are 10x6.5, although the inside of the ductwork has a slot that all of the air is coming out of that’s smaller (picture below) at 7.5 x 3 inches. A couple of questions..
1. Can this register be reduced in size or does it need to stay 10x6?
2. The best option I’ve come up with to make this area look decent is using a thick baseboard register since it will be the same depth or deeper than the tile. Are there any better options for making this area look good? Basically I don’t want the tile that I notch out for the register to be thicker than the register itself (same idea as with baseboards). Also I don’t really know if I can move the register since it’s trapped between the 2 studs.
I am ripping out this drywall BTW.
