Do I need to have sheet metal duct and boot all the way to the register/vent, or can i drop the duct into a wall space and use insulation and sheet rock to channel the air to the register?
1. You can drill though your joists provided they are tji joists and you follow their guidelines. If they are regular 2x10 joists then no can do.Sorry to hi-jack again, but since you're looking at this thread - can I ask you a question? I need to move 2 heater ducts 3 feet each. One has to go through 2 or 3 joists (on an angle). Can I cut and sister them? Should I use a 2" pipe to minimize the cut? The other has to go along the joists, but I wonder. do you just cut the floor boards and patch the hole, or try to remove and replace them as complete pieces? Thanks.
